Yoda3647
Jul 12, 2021Aspirant
Step by Step instruction/help
I just purchased me a used ReadyNas Pro 4 with 4 - 4TB hard drives allready installed. I have been trying for the past 2 days to try and get it to be seen on the Readcloud but it keeps saying I have ...
Jul 12, 2021Guru - Experienced User
Step by step for OS-6 conversion:
(Optionally) make sure the latest BIOS is installed before you do the conversion. To do this you install http://www.readynas.com/download/addons/x86/4.2/BIOS_Update_Package_0.5-x86.bin as an add-on and reboot the NAS. Do this after you backup the NAS. This isn't necessary, but if you do want to update the bios it is easiest to do it prior to conversion
Basic instructions for the conversion itself are
- BACKUP, BACKUP, BACKUP
- Upload PREPR4TOR6_0.1-x86.bin as an add-on using the ReadyNAS web gui, but do not reboot afterwards (avoids the need to do manual factory resets)
- Upload R4toR6_6.9.5.bin using the ReadyNAS web gui firmware update
- After you upload the addon+firmware and reboot, it will update the firmware and start a factory default.
- Go through the setup process on the converted NAS
- Update the NAS to the current OS 6 (check for updates will work).
- Restore files from the backup.
There is a small risk that the process could fail, and if that were to happen it might not be possible to get the NAS running again.
As far as RAM goes, the Pro4 only has one memory slot and it uses DDR2 RAM. While there are some 4 GB modules that will work, most of them won't - and the ones that do are very expensive. I recommend sticking with 2 GB. Any 240 pin PC2-6400 DDR2 ram module will work, and you should be able to find something suitable for ~20 USD or less.
