Yoda3647
Jul 12, 2021Aspirant
Step by Step instruction/help
I just purchased me a used ReadyNas Pro 4 with 4 - 4TB hard drives allready installed. I have been trying for the past 2 days to try and get it to be seen on the Readcloud but it keeps saying I have ...
Yoda3647
Jul 13, 2021Aspirant
I have done that same results. I even tried hooking up a second ethernet cable and tried logging into that ip address same thing the difference in adrress is the last instead of .16 is .22. I will try a couple of more times while waiting on your reply about if I ned to go ahad and reset before I add any more data
Jul 13, 2021Guru - Experienced User
I'd disconnect the second cable, and try restarting the NAS. Then see if you can connect directly https://nas-ip-address/admin (not using ReadyCloud).
If that still gives you the timeout, then I'd do an OS reinstall on the NAS.
- Yoda3647Jul 13, 2021Aspirant
Ok, will try that. Thanks for all your help. Can I get your opinion on this listing
(https://www.ebay.com/itm/294220553452?epid=26012512731&hash=item4480e95cec:g:NZwAAOSwTcxgizLb)
would that be a good price if so, I can gift the one I am working on now to my mom
How long does it take to restart??? The screen say Booting.... it's been like that now for over 20 minutes???
- StephenBJul 13, 2021Guru - Experienced User
It shouldn't take that long. Perhaps let it run a while longer, then see if it completes. If you forcibly powered down (likely since you can't log in), the volume or OS partition might need to be rebuilt.
Still says booting.... I open up RAIDar and it says System Staring up.. Is this one bricked or what else can I do??
Try shutting it down and starting it up again.
Did that still doing the same the LED screen say "Booting..." and the On buttom blinking blue the HD lights are all on steadyand has been that way for over 1 hour. What to try next???
- SandsharkJul 13, 2021Sensei
Yoda3647 wrote:Can I get your opinion on this listing
Not a bad price if the drives are going to provide you enough storage and they are in good shape. Pre-COVID, I would have said it's high, but prices have gone up. If the drives don't suit your use and you're going to replace them, then it's a tad high. I see it's been sold -- did you buy it?
The unit's probably not bricked, but the OS partition may have problems. Once the OS is installed from the flash, it boots from the drives, not the flash. A factory default is the best next step, since you have no data on it you need to keep. To keep it simple and fast, you could do that with just one drive initially to see that the conversion went well.
- Yoda3647Jul 14, 2021Aspirant
Okay will try factory reboot with just one drive. does it matter wich drive and I am assuming it drive spot number 1. to do the Factory reset I turn the unit off the with tooth pick push the factory rest button??
- StephenBJul 14, 2021Guru - Experienced User
You could try just rebooting with only one drive in place. First try drive 1, then try drive 2.
A factory reset would use the process in the hardware manual - page 21-22 here: https://www.downloads.netgear.com/files/GDC/RNDU2000/ReadyNAS_Ultra_UltraPlus_NVX_Pro_HW_en_8July11.pdf
You could also try the OS reinstall first.
FWIW, per the photos, the drives are 10 years old - so they might not last much longer. There was a diskless RN424 listed that was slightly cheaper, that might be worth considering also.
- Yoda3647Jul 15, 2021Aspirant
Okay, I havw been at hospital for the past 2 days and left the NAS running with one drive in it. Got home and it is up and running I was able to login to Admin page and all. Question now is I stuck the other 3 drives in and the NAS is still only showing 3.63 TB available, but when I go to Volumes it show the available one in Blue and the other 3 in Black. I tried restarting but still the same how to I get the NAS to expand and use all 4 drives??
- Yoda3647Jul 16, 2021Aspirant
Okay I selected eachone and click Format, It's something about erasing all information and the disc would then be used to expand then told me to type in "FORMAT SELECTED" I did and waited then it finished but the Nas still only shows the one hard drive Blue the other 3 are Black and on the overview tab still only shows 3.63TB. On the Volume tab under the picture of the NAS it shows "blue square (RAID 1 then a green square ) If I use RAIDar it shows all 4 weith check marks and Healthly
- StephenBJul 16, 2021Guru - Experienced User
Yoda3647 wrote:
Okay I selected each one and click Format, It's something about erasing all information and the disc would then be used to expand then told me to type in "FORMAT SELECTED" I did and waited then it finished but the Nas still only shows the one hard drive Blue the other 3 are Black and on the overview tab still only shows 3.63TB. On the Volume tab under the picture of the NAS it shows "blue square (RAID 1 then a green square )
Is the NAS set up to use XRAID? Look at the XRAID control on the volume tab - if it has a green stripe across it, then you are using XRAID.
yes, the XRAID has a green strip/line through it
Try removing and then reinserting one of the disks (with the NAS powered up), and see if that triggers the expansion. You could also try rebooting.
Another option is to connect the drives to a PC, and either unformat them or zero them. Then hot-insert them into the NAS.
I put 1 back in and it is still black but has a green light/square.Like the Blue one has the same green light/square I will let this sit (got go back to Hospital be gone for about 5 hrs) and see what happens it nothing how do I "unformat or Zero them out" hot swop I am assuming means to just add the disc to the NAS as it is running????
Yoda3647 wrote:
hot swap I am assuming means to just add the disc to the NAS as it is running????
Yes. (though in this case it means remove and then reinsert with the NAS running).
In a windows PC, you unformat a disk by launching the Microsoft Disk Manager. You then select each partition (Microsoft calls them volumes), and remove it.
The easiest way to zero a disk is to use the manufacturer diags (Seatools for Seagate, Western Digital Dashboard for Western Digital). They both have a erase / write zeros test. In the case of Seatools, it is an advanced test, so there is an extra step needed for the test to be shown.
If the diag offers a "quick" write zeros/erase test, then it is fine to use that. It erases enough to clear out the partition info.
- SandsharkJul 17, 2021Sensei
You probably don't want to do that. It will re-sync each one at a time. That test also probably indicates at least one of the drives has a problem. The next thing to do is power down, move the drive to the next slot, and power up; then repeat till, you go through them all. If it boots in all positions, then the NAS hardware isn't the problem.
The next best step would be to check the drives (including the one you used for the single drive test) with vendor tools using a PC. Since a sync isn't required for a single-drive installation, there could still be bad sections of the disk that worked alone that just didn't get used.
But if you really want to just go for it all, you have to select each drive and format it to erase any residual formatting from the failed installation.
- Yoda3647Jul 17, 2021Aspirant
What I ended up doing was using the 3 drives not being used . Installing them taking out the 1st one then resting the NAS now it is seeing the 3 drive and right now it's saying Volume syncing(78.1% complete). My plan is after Scncing is complete I want to hadd back the 1st drive,..Can I just stick it in?????
Thanks for all your help. you can mark the post as closed
- Yoda3647Aug 04, 2021Aspirant
Okay sorry but I guess not solved, I gave this one to my Mother after it was setting here plugged in ad runing for a week. After getting it to mom's house plug it in have on her PC log into it she can see it even hooked t to here TiVo but it keeps going off Line the last time it did this this is what the NAS had on it's display " tcp_prequeue+e2 " any clue as to what this means???
- StephenBAug 05, 2021Guru - Experienced User
That's where the NAS crashed.
Did you ever upgrade the memory to 2 GB (as we suggested early in the thread)? Running out of memory could cause that problem.
- Yoda3647Aug 05, 2021Aspirant
Not yet waiting for it to come in. I told my mom that could be the problem. Thanks
- elaplaceAug 07, 2021Aspirant
You need the Software Manual.
https://www.downloads.netgear.com/files/GDC/READYNAS-100/READYNAS_OS_6_SM_EN.pdf
