Yoda3647
Jul 12, 2021Aspirant
Step by Step instruction/help
I just purchased me a used ReadyNas Pro 4 with 4 - 4TB hard drives allready installed. I have been trying for the past 2 days to try and get it to be seen on the Readcloud but it keeps saying I have ...
Aug 07, 2021Guru - Experienced User
elaplace wrote:
You need the Software Manual.
https://www.downloads.netgear.com/files/GDC/READYNAS-100/READYNAS_OS_6_SM_EN.pdf
This is a converted 4.2.x NAS, and the stock 1GB of RAM is often not enough for OS-6. That's a problem that's been reported by other users. The error on the LCD is a crash, and the most likely cause is an out-of-memory condition.
While the manual doesn't address that topic, it is certainly something that Yoda3647 will find useful.
elaplace
Aug 07, 2021Aspirant
I made a mistake. It a ReadyNAS Ultra 6, no plus.
Can ReadyNAS Ultra 6 Plus update to the OS 6 by the steps above?
- SandsharkAug 07, 2021Sensei
Both the Ultra6 and Ultra6Plus can be updated to OS6 using that procedure. It is advisable that you first upgrade RAM to at least 2GB, as some users have reported problems (starting with OS6.10) when only the stock 1GB of those units is installed.
- elaplaceAug 07, 2021Aspirant
Thank you for your suggestion .
