bspachman
Nov 15, 2010Aspirant
Step-by-Step: Rsync to Local USB
UPDATE: 11/16/2010 LAST UPDATE: 11/17/2010 -------------------------------------- It would be great to create a step-by-step guide to backing up a ReadyNAS to a local USB drive for those of us ne...
dachtler
Nov 17, 2010Aspirant
mdgm wrote: You need to specify volume C as the source and the USB disk as the remote rsync target.
See Rsync backup to USB disk
I guess that's what I'm saying is that I don't know how to specify volume C as the source. According to the guides I've read, you specify the share without a leading / as the target. I have found nowhere where it tells how to specify the volume.
If I leave the path blank, I can't save the backup job (even though I can successfully connect via the rsync test).
If I try to specify "c", then I get an error with the rsync test.
Any hints? Do I need to create the job via FrontView, then SSH to the Duo and edit the file?
