bspachman
Nov 15, 2010Aspirant
Step-by-Step: Rsync to Local USB
UPDATE: 11/16/2010 LAST UPDATE: 11/17/2010 -------------------------------------- It would be great to create a step-by-step guide to backing up a ReadyNAS to a local USB drive for those of us ne...
dachtler
Nov 17, 2010Aspirant
bspachman wrote: I'm not sure which version of RAIDiator the Duo runs, but on my Pro, in the Source step (when creating a FrontView backup), the drop down list has "Volume: c" as an option. I believe everything else in the 'Source' step can then remain blank, and the destination can be configured as the rsync job.
If 'volume: c' is not an option in your drop-down menu, one of the gurus will have to weigh in... :)
Hope that helps....
brad
This definitely helps. I was trying to create the backup job with rsync in the source, and the USB drive as the destination. It didn't occur to me to try and switch them. Duh. Thanks, Brad.
