CharlesR
Jan 30, 2015Guide
Storage Options
I have a Pro 4 (running OS 6.x) I'm looking at and if I decide it's a keeper I'm trying to figure out which storage option I want to go with... 1 - 6TB drive - and expand as I go. 4 - 3TB drives ...
CharlesR
Jan 30, 2015Guide
Ixa wrote: Take note that there is NO support if you put OS 6 on your Pro 4. However, you could browse the ReadyNAS forums for references:
There is nothing about the Pro 4 that is supported and per my post it's strictly OS 6.x related. :) With OS 6.x I think most (all) expansion restrictions have been lifted and I just want to be clear whether the older hardware comes into play and has its only set of restrictions. Especially since adding drives might be far down the road and going factory resets might get more difficult (ensuring a good backup exists). Again the data isn't of high importance...
