CharlesR
Jan 30, 2015Guide
Storage Options
I have a Pro 4 (running OS 6.x) I'm looking at and if I decide it's a keeper I'm trying to figure out which storage option I want to go with... 1 - 6TB drive - and expand as I go. 4 - 3TB drives ...
Jan 30, 2015Guru - Experienced User
Agreed that 6 TB isn't as cost effective, especially if you are wanting RAID-5 or RAID-6.
For instance 3x6 TB gives you 12 TB RAID5 for ~$810
4x4TB the same volume size for $640.
You could go with 4 TB, not sure why you are only considering 3 and 6.
