couch_potatoe
Sep 01, 2012Aspirant
Strange behaviour with "Toggle_ReadyDLNA_Debug_1.0"
Hi,
I've been having issues streaming media (mainly mkv video) from my ReadyNAS 1100 (4.1.9 and ReadyDLNA 1.0.25) and my Sony Bluray player and decided to use the Toggle_ReadyDLNA_Debug add-on to investigate further (issue now fixed - building mkv's slightly differently!). However if I run the add-on again to remove it, it breaks the DLNA server.
Re-installing the add-on fixes the problem but DLNA runs with debugging turned on, and it would appear that every time I run the add-on to disable it I get no DLNA service and an sqlite related problem in the log file.
Anyone have any bright ideas as to how I can fix this so DLNA runs without the debug log?
Thanks!
Andy B.
Thanks!
Andy B.
1 Reply
- couch_potatoeAspirantThis may be a red herring, but looking at this a little more (having picked Toggle_ReadyDLNA_Debug_1.0.bin apart) I have a sneaking feeling that the issue is in /etc/minidlna.conf...
The end of my file (with debug turned on) looks like this:
# notify interval in seconds. default is 30 seconds.
notify_interval=900
# serial and model number the daemon will report to clients
# in its XML description
log_level=general,artwork,database,inotify,scanner,metadata,http,ssdp,tivo=debug
[EOF]
"log_level=" looks ok (considering debug is activated), but it wouls appear that "serial=" and "model=" have gone walkies for some reason, I'm wondering if there is anything else missing...
Would someone mind posting a "clean" version of their "working-without-debug" minidlna.conf file for me to play with? :)
Thanks,
Andy B.
