marcusp
Dec 27, 2012Tutor
Strange performance results with my ReadyNAS Pro 6
I've just bought a Pro 6 to replace my NV+ and for now there are 4xBarracuda in it. I've done some bench in CIFS after reading this subject: http://www.readynas.com/forum/viewtopic.php?f=21&t=6421 ...
Dec 27, 2012Guru - Experienced User
I don't think your router supports jumbo frames. You can confirm by pinging the NAS from the PC:
run cmd (by typing cmd in the windows search bar), and enter
ping xxx.xxx.xxx.xxx -f -l 8000
where xxx.xxx.xxx.xxx is the IP address of the pro.
If you see "packet needs to be fragmented but DF set" then you can't use jumbo frames.
