hajo_s's avatar
hajo_s
Streaming timeout on 104?
Hello community,   Since recently - I suspect since firmware update 6.2.5 - my 104 disconnects streaming sessions after 30 minutes. I have turned off harddisk spin down to test but it still disconn...
  • hajo_s's avatar
    hajo_s
    Oct 07, 2015
    After further investigation I'm pretty sure now that those periodic cleanup scripts kill the streaming. I'm not exactly sure where php5 comes from -- is this a package originally bundled by Netgear or did I do something silly and installed it? I personally don't need it; unless another app I installed requires it. But since my apps are gone, I could remove php as well.
    I have meanwhile changed the cron tab entry to run once a day when I sleep.
    So thx once again Jenn, your guess about load was correct at the end :) Well, I learned my lesson. A Netgear 104 NAS is a NAS, not a full-blown Linux box. Can live with that...
ProSupport for Business
