TommyD760
Dec 01, 2017Guide
Stuck booting. ReadyNAS NVX
Hi Everyone. I was given a ReadyNAS NVX from my neighbor that is stuck at “Booting...”. He gave it to me knowing that I have a ReadyNAS box. I have been reading a lot on here and on Googl...
- Dec 10, 2017
After 6 USB sticks, and constant messing around with Disk Part, USB recovery 6 (which I kow wont work with my 32 bit box), USB recovery 4, Formating the USB in OSX and Windows...
I dont know what happen, but I booted off the USB!!
It did its thing, and the box shut down. On reboot I got an error, but booted to factory reset... Bingo Im back in business!
Turning on quotas.
Initializing random number generator... done.
Starting frontview boot scripts: frontview_rc.
Starting portmap...done.
Starting system log daemon: syslogd.
Starting deferred execution scheduler: atd.
Starting kernel log daemon: klogd.
Starting periodic command scheduler: cron.
Starting Samba daemons: smbd.
No ntpd found running; none killed.RAIDiator 4.2.31 [192.168.1.241]
nas-AA-15-30 login:
Dec 01, 2017Guru - Experienced User
How does it behave if you power it up with no disks installed.
- TommyD760Dec 01, 2017Guide
Wow, Didn’t even think of that. Just tried it and its the same. “Booting...”
- StephenBDec 03, 2017Guru - Experienced User
Maybe check the seating on the memory cards next.
- TommyD760Dec 04, 2017Guide
No memory problems reporting with the boot menu test. I was able to connect to the serial port.
Below is the output from the cable.
Having a problem now with the USB recovery stick. Cant seem to get it created correctly. Ill keep trying. If anyone has any hints, please throw them my way!
Thanks
--tom
Boot up.
SYSLINUX 3.31 v1.06 Fri Jul 9 18:03:04 PDT 2010
Copyright (C) 1994-2005 H. Peter Anvin
Debug Serial Port Enabled
Normal
FactoryDefault
OSReinstall
TechSupport
SkipVolCheck
MemoryTest
TestDisks
Loading
18
1B
To Be Filled By O.E.M.
11/17/2008 ReadyNAS-NVX V1.3
kernel..................................................
Loading initrd.gz.....................................................................Ready.
[Hardware Error]: No human readable MCE decoding support on this CPU type.
[Hardware Error]: Run the message through 'mcelog --ascii' to decode.
▒ahci 0000:03:00.0: masking port_map 0x7 -> 0x3
request_module: runaway loop modprobe binfmt-464c
sd 5:0:0:0: [sdb] Assuming drive cache: write through
sd 5:0:0:0: [sdb] Assuming drive cache: write throughOS Reinstall
Normal
FactoryDefault
OSReinstall
TechSupport
SkipVolCheck
MemoryTest
TestDisks
Loading aborted.
Normal
FactoryDefault
OSReinstall
TechSupport
SkipVolCheck
MemoryTest
TestDisks
Normal FactoryDefault OSReinstall OSReinstall
Loading
18
1B
sd 5:0:0:0: [sdb] Assuming drive cache: write throughTech Support
Normal
FactoryDefault
OSReinstall
TechSupport
SkipVolCheck
MemoryTest
TestDisks
Loading aborted.
Normal
FactoryDefault
OSReinstall
TechSupport
SkipVolCheck
MemoryTest
TestDisks
Normal FactoryDefault OSReinstall TechSupport TechSupport
Loading
18
1B
