TommyD760
Dec 01, 2017Guide
Stuck booting. ReadyNAS NVX
Hi Everyone. I was given a ReadyNAS NVX from my neighbor that is stuck at “Booting...”. He gave it to me knowing that I have a ReadyNAS box. I have been reading a lot on here and on Googl...
- Dec 10, 2017
After 6 USB sticks, and constant messing around with Disk Part, USB recovery 6 (which I kow wont work with my 32 bit box), USB recovery 4, Formating the USB in OSX and Windows...
I dont know what happen, but I booted off the USB!!
It did its thing, and the box shut down. On reboot I got an error, but booted to factory reset... Bingo Im back in business!
Turning on quotas.
Initializing random number generator... done.
Starting frontview boot scripts: frontview_rc.
Starting portmap...done.
Starting system log daemon: syslogd.
Starting deferred execution scheduler: atd.
Starting kernel log daemon: klogd.
Starting periodic command scheduler: cron.
Starting Samba daemons: smbd.
No ntpd found running; none killed.RAIDiator 4.2.31 [192.168.1.241]
nas-AA-15-30 login:
Dec 01, 2017Guru - Experienced User
How does it behave if you power it up with no disks installed.
TommyD760
Dec 01, 2017Guide
Wow, Didn’t even think of that. Just tried it and its the same. “Booting...”
- StephenBDec 03, 2017Guru - Experienced User
Maybe check the seating on the memory cards next.
- TommyD760Dec 04, 2017Guide
No memory problems reporting with the boot menu test. I was able to connect to the serial port.
Below is the output from the cable.
Having a problem now with the USB recovery stick. Cant seem to get it created correctly. Ill keep trying. If anyone has any hints, please throw them my way!
Thanks
--tom
Boot up.
SYSLINUX 3.31 v1.06 Fri Jul 9 18:03:04 PDT 2010
Copyright (C) 1994-2005 H. Peter Anvin
Debug Serial Port Enabled
Normal
FactoryDefault
OSReinstall
TechSupport
SkipVolCheck
MemoryTest
TestDisks
Loading
18
1B
To Be Filled By O.E.M.
11/17/2008 ReadyNAS-NVX V1.3
kernel..................................................
Loading initrd.gz.....................................................................Ready.
[Hardware Error]: No human readable MCE decoding support on this CPU type.
[Hardware Error]: Run the message through 'mcelog --ascii' to decode.
▒ahci 0000:03:00.0: masking port_map 0x7 -> 0x3
request_module: runaway loop modprobe binfmt-464c
sd 5:0:0:0: [sdb] Assuming drive cache: write through
sd 5:0:0:0: [sdb] Assuming drive cache: write throughOS Reinstall
Normal
FactoryDefault
OSReinstall
TechSupport
SkipVolCheck
MemoryTest
TestDisks
Loading aborted.
Normal
FactoryDefault
OSReinstall
TechSupport
SkipVolCheck
MemoryTest
TestDisks
Normal FactoryDefault OSReinstall OSReinstall
Loading
18
1B
sd 5:0:0:0: [sdb] Assuming drive cache: write throughTech Support
Normal
FactoryDefault
OSReinstall
TechSupport
SkipVolCheck
MemoryTest
TestDisks
Loading aborted.
Normal
FactoryDefault
OSReinstall
TechSupport
SkipVolCheck
MemoryTest
TestDisks
Normal FactoryDefault OSReinstall TechSupport TechSupport
Loading
18
1B
sd 5:0:0:0: [sdb] Assuming drive cache: write through- TommyD760Dec 07, 2017Guide
Latest update...
Really having a hard time creating the USB recovery sticks. Finally ordered some 2GB ones and its the closest I have been. Now when I boot from the USB I get.
Reboot and Select proper Boot device
or Insert Boot Media in selected Boot device and press a keyI usually had nothing! Getting closer... Anyone have any hints / help?
