TommyD760
Dec 01, 2017Guide
Stuck booting. ReadyNAS NVX
Hi Everyone. I was given a ReadyNAS NVX from my neighbor that is stuck at “Booting...”. He gave it to me knowing that I have a ReadyNAS box. I have been reading a lot on here and on Googl...
- Dec 10, 2017
After 6 USB sticks, and constant messing around with Disk Part, USB recovery 6 (which I kow wont work with my 32 bit box), USB recovery 4, Formating the USB in OSX and Windows...
I dont know what happen, but I booted off the USB!!
It did its thing, and the box shut down. On reboot I got an error, but booted to factory reset... Bingo Im back in business!
Turning on quotas.
Initializing random number generator... done.
Starting frontview boot scripts: frontview_rc.
Starting portmap...done.
Starting system log daemon: syslogd.
Starting deferred execution scheduler: atd.
Starting kernel log daemon: klogd.
Starting periodic command scheduler: cron.
Starting Samba daemons: smbd.
No ntpd found running; none killed.RAIDiator 4.2.31 [192.168.1.241]
nas-AA-15-30 login:
TommyD760
Dec 08, 2017Guide
Using Windows 10... After trying just letting windows format it, i figured i will try using diskpart.
Commands I used in diskpart...
clean
convert mbr
create part pri
format fs=fat32 quick
Then I used the USB recovery software on it, (right click and ran as administrator) After completes, use windows and eject.
Single drive in Slot 1 of NAS box. Power off... Wait 10... Power on holding backup button with USB stick in front slot.
Console clears screen, and then I get:
Reboot and Select proper Boot device
or Insert Boot Media in selected Boot device and press a key
Still think its user error with making the usb recovery. anyone have a something else i can just dd or something for it?
TommyD760
Dec 10, 2017Guide
Turning on quotas.
nas-AA-15-30 login:
- SandsharkDec 11, 2017Sensei
The ReadyNASes, especially older ones, are very particular about the USB stick you use. I didn't try 6. But after 2 that failed, I remembered I had a really old 2GB that was considered big in its day. It worked like a champ. Glad you finally found the right combo.
