mrichmon
Oct 10, 2011Aspirant
Sudden SSH problems
I have had my ReadyNAS Pioneer Pro running for a couple of years with the EnableSSH add-on. Sometime in the past week I have lost the ability to ssh to the ReadyNAS. When attempting to SSH as root I g...
mdgm-ntgr
Oct 12, 2011NETGEAR Employee Retired
If you do a factory reset, update to latest firmware first (be sure to verify update is successful) so you can get a clean install of the latest firmware. If you can't update firmware, do factory reset with one disk installed, update the firmware (verify update is successful), then factory reset with all disks in place
