exibar
May 18, 2022Aspirant
swapping drives from a rn 214 over to a rn104
Hi all! after fighting with a Sans Digital NAS, that nearly litterally cooked a couple drives they got so hot, I aquired an RN104 to compliment my existing rn214. I was not able to find a...
Sandshark
May 18, 2022Sensei
Short answer: Yup!
Longer answer: It's best to insure the new chassis has the same OS version as the old before you do it. If it's not, it'll be a case of "most recent wins" and either the unit flash or the OS on the drives will update to the newer one. It is extremely important to do this if either unit is on a very old version. The release notes explain what multiple steps must be taken to upgrade some ARM units when making a big jump in versions.
And not asked: You could have gone to any OS6 based NAS with 4 or more bays. The 104 is memory restricted (and cannot have memory expanded), so is going to run slower. If you're relegating it to backups, then it probably doesn't matter.
exibar
cool, so make sure they are both running the same OS version. If not upgrade them (or the one not running the latest version), then I can swap the drives over, nice.
yah I'll jsut be using the 104 to serve up files for my plex server that will connect to it via UNC path. the only 214 I could find was like $450 on ebay, and I didn't want to pay that much for it as I bought this one for $250 filled with drives LOL. The 104 was less than what I paid for the 214 so I jumped on it.
I'll keep my eyes out for a 214 though, I really like it.
but you said I can swap into a 6bay or 8bay as well huh? nice I'll keep my eyes open for one of them.
quick question, if I get a 6 bay, can I expand the raid5 array just by adding 2 additional drives? or do I have to rebuild the entgire array then restore from backup?
thanks!
Mike B
