arnomc
Mar 18, 2015Aspirant
switch drive from a x86 readyNas to an ARMv7 (like RN102)
I am happy with my 2 bay atom readyNAS under 6.2.2, but I am considering buying for cheap a RN102 for 2 reasons : 1) could use it for remote backup my main NAS 2) could buy it in case of hardware f...
RX
Mar 18, 2015Luminary
arnomc wrote: IF I unplug drives from a x86 and put them into a RN102, I am wondering that the image of system is compiled differently so it's not going to boot as simply as this, isn't it ? BUT is there a way to reinstall a RN OS6 and then boot and use directly my data ? (maybe with the use of a reconfig file or manually reconfiguration of shares..).
If all those ideas are impossible to achieve without loosing all the data, then I might considering using an additional RN102 only for remote backup !
Its not advisable to just pull-out your exisitng drives from your x86 NAS then simply insert it to the RN102. It would be best if you back up the data from your x86 NAS to an external drive or free space on your PC/laptop. Then, if ever you have the RN102 in hand, you may transfer the backed up data to it.
Check this link: http://kb.netgear.com/app/answers/detai ... os6-nas%3F
