rmaeder
Apr 19, 2014Aspirant
System clock and spindown on NV+
Past February I enabled disk spindown on my NV+ (4.1.13, with 4 disks). This works nicely, but now I noticed that since then the system clock is very inaccurate. The system runs ntpdate every 4 hours,...
Apr 19, 2014Guru - Experienced User
I am not seeing this behavior on my NV+ or my duo (both have spindown enabled). There are a couple of entries that reach 0.44 seconds, but the .0x range is what it usually is. Nothing in the 10s of seconds.
What drives are you using? I'm wondering how much power they draw during spinup.
