rmaeder
Apr 19, 2014Aspirant
System clock and spindown on NV+
Past February I enabled disk spindown on my NV+ (4.1.13, with 4 disks). This works nicely, but now I noticed that since then the system clock is very inaccurate. The system runs ntpdate every 4 hours,...
Apr 20, 2014Guru - Experienced User
Correlation with the spindown period suggests that the clock is running slower when the disks are spun down. The longer the spindown, the more time it loses.
What hardware version is your NV+? It should be on the back label (v3 or some such). I can check mine as well - possibly mine is different, which might explain why I am not seeing it.
How much do you want spindown?
Perhaps one option is to contact Netgear support and buy a replacement PSU. That is speculative, but possibly might help.
