rmaeder
Apr 19, 2014Aspirant
System clock and spindown on NV+
Past February I enabled disk spindown on my NV+ (4.1.13, with 4 disks). This works nicely, but now I noticed that since then the system clock is very inaccurate. The system runs ntpdate every 4 hours,...
tony359
Apr 20, 2014Apprentice
If you disable disk spindown, does the clock go back to what it used to be?
Are you sure your NTP server is accurate and not freewheeling?
