rmaeder
Apr 19, 2014Aspirant
System clock and spindown on NV+
Past February I enabled disk spindown on my NV+ (4.1.13, with 4 disks). This works nicely, but now I noticed that since then the system clock is very inaccurate. The system runs ntpdate every 4 hours,...
tony359
Apr 20, 2014Apprentice
Not a massive expert here, but CMOS clock and Kernel clock should be two different things? The Kernel clock is usually generated by CPU cycles, but it really depends on the system and if alternative timers are provided by the MB. On my Pro 6 "hwclock" (BIOS clock) was still on year 2002, I have synced with the system time (hwclock --systohc), let the HDD spin down, access the NAS again and checked again. No change, both clocks are still ok.
As Stephen says, I'd change that battery anyway. If that does not fix, I'd search the internet for a similar problem with Debian 4
