Digital999
Jan 29, 2025Luminary
System not recognized in Windows connection
Perfectly operational ReadyNAS 626 system as of one week ago. Installed and recognized for the past three years. Connected and operational on five different Windows workstations. RAIDar can...
Sandshark
Jan 30, 2025Sensei
You do need to re-boot for edits of the hosts file to take effect.
Also, your error message is The local device name is already in use not an indication that the name is wrong or misspelled? The first command StephenB listed should have cleared all names that were in use. So try this and post exactly what responses you get.
net use
net use * /delete
net use
net use z: \\nas-ip-address\data /u:admin nas-admin-password
net use
If the second command warns you that you are deleting an active connection, reply YES.
I am expecting you will get different responses to each of the net use commands with no arguments.
What I suspect is that you have something that is attempting to automatically mount the NAS that is failing (quite likely simply a persistent drive mapping), but Windows is unaware it failed. So any attempt to re-mount it will give that error message. Now the thing is to find why it failed.
Digital999
Jan 31, 2025Luminary
Problem still exists but...
Fat fingering at is worst at the wrong time.
Firefox as the default browser. Recently we have been having some issues with Firefox -- switching to Chrome has exposed some fields in the browser display that Firefox does not display. Seems to be more prevalent on some banking applications and some Microsoft sites. That issue will be investigated separately.
Using Chrome login to the ReadyNAS is possible directly using the IP address (not fat fingered).
Using FileManager login to the ReadyNAS is possible from FileManager using the IP address which 'calls' on a browser to in turn direct to the IP address. Works.
This issue does not present with the Synology NAS on the same subnet.
My tentative conclusion is that ReadyNAS system is responding properly and connectivity is not an issue.
The issue is Windows based.
My next step is going to rename the ReadyNAS system since the Windows error messages indicate it is 'misspelled' or possibly the name is used. The Windows error messages vary between those two depending on the context of access attempts.
Will advise as to the result.
