Digital999
Jan 29, 2025Luminary
System not recognized in Windows connection
Perfectly operational ReadyNAS 626 system as of one week ago. Installed and recognized for the past three years. Connected and operational on five different Windows workstations. RAIDar can...
Jan 31, 2025Guru - Experienced User
Digital999 wrote:
Using FileManager login to the ReadyNAS is possible from FileManager using the IP address which 'calls' on a browser to in turn direct to the IP address. Works.
This is not using SMB for access.
What happens if you use \\192.168.0.239 ?
Digital999
Jan 31, 2025Luminary
Using \\192.168.0.239 works fine.
FileManager opens with the appropriate directories enumerated. Can look at files and other stuff using FM
Sorry, I did not understand difference between SMB and your approach.
