CarlEdman
Jun 11, 2017Luminary
System Suddenly Very Loud
Recently I noticed that my NAS (Legacy Ultra 6 Plus, with upgraded CPU and memory, running 6.7.4), which until then had been near-inaudible except possibly during boots or shutdowns, had become very loud. There has been no change in location for years (a well-ventilated cool closet). Nor do any of the disks give any indication of failing (not that the sound had that characteristic noise).
So I suspected the fans and pulled up the relevant dashboard page:
[Hmm, didn't there use to be a way to upload images to this forums? Or is that just all other forums? It is a pretty useful feature. In any case, here is the relevant part of the screenshot: http://i.imgur.com/7Y5GeqA.png]
The first thing I noticed that these fan controls look new to me. They are neat, but they might be connected to the problem. Disk temperatures are fine. CPU a little high, but not alarming. However, the reported "System" temperature sounds really high; not system about to meltdown high, but completely unreasonably high. Could this possibly be correct? Or could it be related to a vaguely remembered issue with ReadyNAS 6 not reading certain sensors on legacy hardward correctly?
In any case, the high reported System temperature is probably the reason that the fans are running at full speed and high noise. Switching between Quiet, Balanced, and Cool fan modes has no effect. I imagine that is the correct result in circumstances that the system feels that it needs all the cooling it can get, noise be damned.
For what it is worth, the noise issue definitely existed in 6.7.1 and was not fixed in 6.7.4.
So is there anything to be done about this? Or do I just need to find a different, more distant closet to locate the NAS in?
- mdgm-ntgrNETGEAR Employee Retired
What about on ReadyNASOS 6.7.5-T299 (Beta 1)?
- CarlEdmanLuminary
No change, unfortunately. http://i.imgur.com/tNWwlXC.png
- CarlEdmanLuminary
Opened up the box to see if there was anything awry internally, but found nothing except the orderinary amounts of dust which seem to accumulate in electronics. However, nothing felt as warm to the touch as the 50+ degrees centigrade reported for "System." Is it possible that it is this sensor which is miscalibrated?
- CarlEdmanLuminary
Any news on the solution front? After a week, this noise really starts to grind on my ears.
Here are the latest stats, somewhat different than before: http://imgur.com/gallery/q1CYv
- SandsharkSensei
Your system fan is running at a reasonable speed. CPU fan is a bit high. But if that's causing a lot of excess noise, you may have a fan in need of replacement. Your stats are close to mine; my systemn fan is about 100RPM faster. But my computer room may be warmer than yours.
- CarlEdmanLuminary
Hmm. I guess it is possible that the CPU fan went terribly bad (going from inaudible a foot or two away to making a racket six feet and a door away) and the system updates were just a coincidence. Let me see if replacing it with another from my bag of left-over system pieces helps.
And, yes, even in the midst of the current heat wave, the closet is nice and cool, no warmer than 20 degrees Celsius.
