inforcer36
May 12, 2018Aspirant
System Volume Root usage 92%
Tried to access my unit after extended period of inactivity initially everything looked but wouldn't download system update. Tried rebooting and now can't access volume and it shows no shares though...
JohnCM_S
May 12, 2018NETGEAR Employee Retired
Hi inforcer36,
Welcome to the Community!
Do you have any apps running on the NAS? That is usually the cause for full root.
It appears that you have a lifetime chat support on your NAS. It will be best to contact NETGEAR support via chat. They should be able to fix it without data loss.
- inforcer36May 12, 2018Aspirant
well I was running the log analyser, plex, and antivirus. When i first got in and saw i had a problem i was able to remove Plex, but now I can't do anything with any other apps, can't install, activate or even see apps that are installed.
