jwilkinson84's avatar
jwilkinson84
System volume 'root' usage is 100 %
I was wondering what can I delete under the /var/ folder? its taking up around 700MB of space and my admin page is not loading anymore.
  • StephenB's avatar
    How full is the OS partition?  There are other causes for your issue, and it seems likely that a full OS is not your issue.
    What apps do you have installed on the NAS?  Can you post the results of du /var/lib -h -d 1
    • jwilkinson84's avatar
      jwilkinson84
      /Dev/md0 is maxed out at 100%.
      It looks like /Var/Lib is only 528M. The only apps i have is Plex at 2.6GB and Tautulli at around 300M
      • StephenB's avatar
        You have some stuff in /var/lib that I don't, but the main difference in the size is in clamav - I have that turned off.
        If you aren't seeing where the space has gone, then it likely is hiding underneath a mount point.
        Try mount /dev/md0 /mnt and then look in /mnt.  Then you'll only see what is actually stored there.  When finished, do a cd // and then umount /mnt
ProSupport for Business
