andy_vdg
Apr 17, 2016Guide
System volume 'root' usage is 81%
Hi guys, I've got a root volume issue and have found the culprit (I think). # df -h
Filesystem Size Used Avail Use% Mounted on
tmpfs 10M 4.0K 10M 1% /dev
/dev/md0 ...
- Apr 17, 2016
When a service crashes it can leave a core dump. Analysing the core dump can be useful for determining the cause of the problem. So you may prefer to move those to your data volume rather than delete them.
You can delete/move a core dump. The core dump for readynasd from 2014 is very old and unless you are still having issues with the management service you should be able to delete that.
mdgm-ntgr
Apr 17, 2016NETGEAR Employee Retired
- andy_vdgApr 17, 2016Guide
Awesome thanks - moved it to the data folder and all is good again.
Back down to 45%.
df -h Filesystem Size Used Avail Use% Mounted on tmpfs 10M 4.0K 10M 1% /dev /dev/md0 4.0G 1.7G 2.0G 45% / tmpfs 2.0G 4.0K 2.0G 1% /dev/shm tmpfs 2.0G 3.8M 2.0G 1% /run tmpfs 2.0G 0 2.0G 0% /sys/fs/cgroup tmpfs 2.0G 0 2.0G 0% /media /dev/md127 7.3T 6.1T 1.3T 83% /data /dev/md127 7.3T 6.1T 1.3T 83% /home /dev/md127 7.3T 6.1T 1.3T 83% /apps /dev/md127 7.3T 6.1T 1.3T 83% /var/ftp/media
