andy_vdg's avatar
Apr 17, 2016
System volume 'root' usage is 81%
Hi guys,   I've got a root volume issue and have found the culprit (I think).    # df -h Filesystem Size Used Avail Use% Mounted on tmpfs 10M 4.0K 10M 1% /dev /dev/md0 ...
  • mdgm-ntgr's avatar
    Apr 17, 2016
    When a service crashes it can leave a core dump. Analysing the core dump can be useful for determining the cause of the problem. So you may prefer to move those to your data volume rather than delete them.
    You can delete/move a core dump. The core dump for readynasd from 2014 is very old and unless you are still having issues with the management service you should be able to delete that.
ProSupport for Business
