p5taylor
Jan 16, 2018Tutor
System volume root's usage is 84%. This condition should not occur under normal conditions. Contact
Please help.... System volume root's usage is 84%. This condition should not occur under normal conditions. Contact technical support. I keep getting this error, I have a small ammount of kno...
- Jan 16, 2018
p5taylor wrote:Running firmware V6.9.1, I have now also un-install all 3 apps that i had installed come down from 84% to 83%. Is there any way to reset the whole system to factory default and save my data on the hard drives if i remove them?
Support knows how to rebuild the OS from scratch w/o touching the data volume, but I don't.
p5taylor wrote:
248M cache
2.1G libLook further into here. My cache is ~50M, and lib is 384M. Everthing else looks reasonablely close.
p5taylor
Jan 16, 2018Tutor
Hi Steven
Regards
Paul
Jan 16, 2018Guru - Experienced User
p5taylor wrote:
248M cache
2.1G lib
