dweinshel
Mar 17, 2019Tutor
System volume root's usage is 84%. This condition should not occur under normal conditions. Contact
So, I am now receiving this error message and have combed the community.
I see many have this issue but I am still not able to figure out what to do.
I have ssh'ed in to the root directory and can see...
Mar 17, 2019Guru - Experienced User
dweinshel wrote:
I have ssh'ed in to the root directory and can see that /dev/md0 is 89% full. Many posts say to delete this and all will be well.
Absolutely not. The NAS boots from the root partition. You aren't understanding what you are reading.
If you don't have a backup of your data, you should certainly make one.
You could try paid support (my.netgear.com), though they would charge.
However perhaps see if JohnCM_S or OOM-9 offer to take a look - they might want to, since any issues with 6.10 should be solved before it is released.
