KayZak
Nov 01, 2016Aspirant
System volume root's usage is 89%. This condition should not occur in normal conditions.
Hi All, I keep receiving an error message "System volume root's usage is 89%. This condition should not occur in normal conditions. Contact technical support." After some research, I found ro...
dershope
Feb 27, 2017Aspirant
I'm experiencing the same Resilio issue now. I'm able to ssh into the device. From there I'm not sure where to turn. I want to delete the Resilio directory and start over. I've removed the app via the GUI but that does not delete the directory. Its a new unit so I'm not worried about crashing it. Thanks in advance.
Feb 28, 2017Guru - Experienced User
I think you can just delete the Resilio folder
Are you seeing a lot of space usage in /var/cache and /var/log?
You could of course do a factory reset, and rebuild everything from scratch. Overkill, but if you aren't in a hurry it has the advantage of cleaning out everything.
- dershopeFeb 28, 2017Aspirant
I did a restore as I couldn't figure out how to delete the bloated directory via SSH. Now I'm getting messages warning me that less than 20% of media capacity is free. What is that? I created a directory on a new share within the 2TB volume. The sync share is less than 70GB.
- mdgm-ntgrFeb 28, 2017NETGEAR Employee Retired
That suggests that the 4GB root volume is getting full.
Sounds like you've done some of the same things that you did last time.
- dershopeMar 01, 2017Aspirant
I thought the same thing but if that were the case it would be full as the Sync share is 70GB. Also when the root dir was full the error was different.
"System volume root's usage is 98%. This condition should not occur in normal conditions. Contact technical support."
