ViktorN
Mar 17, 2019Tutor
System volume root's usage is xx%. This condition should not occur under normal conditions. Contact
ReadyNAS 104, latest firmware (6.9.5), 4,17TB free of 5,44TB, default antivirus, NO installed Applications, enabled sevices: SMB, NFS, FTP, ReadyDLNA, Rsync, UPnP, HTTP, HTTPS, Antivirus.
Used for ...
Mar 17, 2019Guru - Experienced User
You certainly can contact paid support via my.netgear.com (assuming you are the original purchaser of the NAS) - though they will charge.
I suggest turning off antivirus, and see if that helps. Netgear will be dropping the antivirus service on the RN104 anyway in the next release (6.10.0).
ViktorN
Mar 18, 2019Tutor
Hi Stephen, thank you for your suggestion. I turned off antvirius, after restart it sends me again the same error message (just 1 % mor then before).
I have no problem with paid support,. I have no problem to pay for my mistakes, but I have problem to pay for Netgear mistakes in their SW!
- mnickelsMar 21, 2019Aspirant
ViktorN wrote:I have no problem with paid support,. I have no problem to pay for my mistakes, but I have problem to pay for Netgear mistakes in their SW!
I cannot agree with this statement more. The lack of NetGear official support of this NetGear caused issue is very troubling. Are you listening NetGear...?
- Bolly2007Mar 22, 2019TutorHad same problem on my 104. Was driving me nuts. Turned off AV (real time toggle) and has been sweet so far.
Netgear really needs to do better than this!
