ViktorN
Mar 17, 2019Tutor
System volume root's usage is xx%. This condition should not occur under normal conditions. Contact
 ReadyNAS 104, latest firmware (6.9.5), 4,17TB free of 5,44TB, default antivirus, NO installed Applications, enabled sevices: SMB, NFS, FTP, ReadyDLNA, Rsync, UPnP, HTTP, HTTPS, Antivirus.
 Used for ...
ViktorN
Mar 18, 2019Tutor
Hi asimb, thank you very much for your valuable informations. But how do I get into root? I can only see the directories I created myself. I only have access through ReadyNAS Admin Page (via local www of NAS).
Thanks
asimb
Mar 18, 2019Star
First of all you have to enable SSH on your NAS admin-page (description how to do see https://kb.netgear.com/30068/ReadyNAS-OS-6-SSH-access-support-and-configuration-guides "Enabling SSH access for root using password authentication"). Then you have to start SSH on your windows computer using "ssh root@<ip>.<ip>.<ip>.<ip>" (ip means the ip-adress of your NAS). The password is your admin-password.
then you have to type "cd /var/lib/clamav" and then "ls -la". Then you should see some entrys beginning with "clamav-..." and ending with ".tmp". Please check this.
- mprosMar 18, 2019Initiate
Hi, today i ran into the same issue and solved it with your described steps.
- Enable ssh service and the ssh login permission via accounts > user
- Login e.g. Putty and switch to root via: su -
- Check the size of the root-fs via: du -hsx /* | sort -rh | head -10
(you'll get the following output)
root@STORAGE:~#
du: cannot access '/proc/17259/task/17259/fd/3': No such file or directory
du: cannot access '/proc/17259/task/17259/fdinfo/3': No such file or directory
du: cannot access '/proc/17259/fd/3': No such file or directory
du: cannot access '/proc/17259/fdinfo/3': No such file or directory
3.1G /var <<<<<<<<<<<
185M /usr
30M /frontview
28M /lib
10M /sbin
9.1M /etc
6.1M /opt
6.0M /bin
1.5M /apps
396K /run- change directory to /var/lib/clamav
- stop the following clamav services via: systemctl stop ...
-rw-r--r-- 1 root root 565 Oct 9 21:53 clamav-daemon.service
-rw-r--r-- 1 root root 204 Oct 9 21:53 clamav-freshclam.service
-rw-r--r-- 1 root root 156 Oct 9 21:53 clamav-freshclam.timer
-rw-r--r-- 1 root root 499 Oct 31 05:17 clamav-init.service- delete the temp-folders and (maybe the *.cld-files) via : rm- rf
- disable the clamd-services if needed
- asimbMar 18, 2019Star
Warning: be careful with "rm -rf", because this command is deleting everything in the selected directory! So before using this, be sure, that you are in /var/lib/clamav and not somewhere else. From my point of view it's more secure to use "rm -r clamav-*.tmp".
 - dasgwegApr 18, 2019Aspirant
What's next? How to clean ??
