ViktorN
Mar 17, 2019Tutor
System volume root's usage is xx%. This condition should not occur under normal conditions. Contact
ReadyNAS 104, latest firmware (6.9.5), 4,17TB free of 5,44TB, default antivirus, NO installed Applications, enabled sevices: SMB, NFS, FTP, ReadyDLNA, Rsync, UPnP, HTTP, HTTPS, Antivirus.
Used for ...
May 26, 2019Guru - Experienced User
Watcher-0000 wrote:
Back to trying to do it myself. I can't seem to get in because of a publickey issue.
Can you explain more about this issue?
Watcher-0000
May 26, 2019Aspirant
Hello Stephen B, when trying to log in using Windows Powershell using the command ssh [email protected] I get the following message:
Permission denied (publickey).
Sorry I am not an expert and feeling my way.
- Bell98May 26, 2019Guide
If this helps - I got into mine using Windows PowerShell (Admin). Maybe you're already doing this.
- Watcher-0000Jun 14, 2019Aspirant
Thanks Bell98, yes I am doing what you suggest but no luck.
- StephenBMay 26, 2019Guru - Experienced User
Have you enabled password authentication for ssh in the admin web ui? Look on system->settings->services, and click on ssh.
Sorry for the slow reply, StephenB, I have been away. I may have inadvertently enabled it at one point but have subsequently turned off SSH and turned it back on without password protection. However, login is denied still due to "Permission denied (publickey)". When I did enable it I copied the as a text file which I still have.
In the interim, I note that 6.10.1 is now available which allegedly fixes the antivirus problem (I have only just found the conversations about HF1 and HF2 to 6.10.0). However, as I am 98% full, I am very hesitant to install 6.10.1 without knowing that it can be done and the temp files will be removed during the firmware update.
I am tempted to nuke the thing with a factory reset and then slowly build up the firmware updates again but will that remove the temp files anyway? (And yes, I have a backup of my data).
Anyway, i look forward to your reply. Thanks.
- StephenBJun 15, 2019Guru - Experienced User
You got it backwards - you need to have password authentication enabled.
A factory reset will build a completely new OS partition so all these files will disappear - and it will install your current 6.10.0 firmware, so you won't need to re-apply old ones.
If your volume is very old, you'll also get faster performance if you rebuild from scratch. Netgear has done some tuning to the btrfs setup over the years, but those changes only applied to new volumes.
So this would be a good path overall. Document your settings though (one easy way is to walk through the web ui and make screen shots of key settings).
