ViktorN
Mar 17, 2019Tutor
System volume root's usage is xx%. This condition should not occur under normal conditions. Contact
ReadyNAS 104, latest firmware (6.9.5), 4,17TB free of 5,44TB, default antivirus, NO installed Applications, enabled sevices: SMB, NFS, FTP, ReadyDLNA, Rsync, UPnP, HTTP, HTTPS, Antivirus.
Used for ...
loha
Oct 27, 2019Aspirant
At 8.00 I receive a message from my ReadyNAS 314 "
Användningen av systemvolymen root är 81 %. Det här tillståndet brukar inte uppstå under normala förhållanden. Kontakta teknisk support." (the same as stated in a number of issues below).Translated i say "System volume root's usage is 81%. This condition should not occur under normal conditions. Contact technical support".
My NAS has been upgraded to latest OS 6.10.2. The problem started in the previous OS 6.10.1.
My REadyNAS is configured with 4x4000GB discs Running as RAID5. The usage is 9.42 TB free of 10.90 TB.
How can I clean this up?
It looks like a system fauls. Why wasn't it correcte with the upgrade to latest OS?
Best regards
Lars-Olof
- SandsharkOct 27, 2019Sensei
loha, it is bad practive to "piggy back" on onther posting, as your situation may not be the same and answers meant for one poster get confused with those intended for the other. Please open your own thread.
That said, it's not the OS that typically creates that problem, it's an app. And doing OS updates can make the situation worse because the NAS lacks working space for the upgrade. There are dozens of postings that address this issue, perhpas you should read some before asking the same questions over. The search function of the forum is abominable, use Google instead.
