Zabkareadynas
Aug 07, 2015Aspirant
Temperature spikeon Ultra 2 plus with no activity
I have Ultra 2 running OS 6.2.4 and everything is running fine so far for last 2-days. With all the early threads about temperature & Fan issues, I have been monitoring this alittle closer. My under...
- Aug 09, 2015
Wow, I did not know the downloaded logs had so much more information that what what shown on the gui page.
Yes, you were correct. There was some maintenance performed in the middle of the night. It did not happen the following night.
So far, everything looking good with OS 6.2.4 on Legacy Ultra 2 plus.
Aug 07, 2015Guru - Experienced User
Did you download the logs and check them?
Several things are scheduled periodically, including SMART checks, AV updates, snapshots, ...
Zabkareadynas
Aug 09, 2015Aspirant
- mdgm-ntgrAug 09, 2015NETGEAR Employee Retired
The downloaded logs are intended primarily for support while the status log in the UI is designed to present key information to users in an easy to follow way.
