Retired_Member
Dec 11, 2013"TFTP_REQ" On ReadyNas Ultra 2=RNDU 2000
Hi! My RAIDar is showing "TFTP_REQ" How can I enter TFTP mode on ReadyNas Ultra 2 and what files should I use? I also tried usbrecovery with 4 diffrent usb sticks and it did not work :/ Thank yo...
mdgm-ntgr
Dec 11, 2013NETGEAR Employee Retired
Have you checked that the RAM is properly seated? Sometimes you can get this error due to bad or loose memory.
