Retired_Member
Dec 11, 2013"TFTP_REQ" On ReadyNas Ultra 2=RNDU 2000
Hi! My RAIDar is showing "TFTP_REQ" How can I enter TFTP mode on ReadyNas Ultra 2 and what files should I use? I also tried usbrecovery with 4 diffrent usb sticks and it did not work :/ Thank yo...
Retired_Member
Dec 16, 2013So I grapped a usb to ttl, because warranty is not an option anymore.
This is what the serial port gives me:
And this is when i try usbrecovery:
Yes I have tried many usb sticks.
As when mdgm tried to help me,
mdgm told me there is something wrong with the internal memory and it seems to be right
The guestion now is, is this a software or hardware error?
and is there a way to fix it?
reflow/reball is not a problem.
Starting the boot process...
Loading kernel modules...done
ERROR: No disks detected!
Bringing up network...done
Extracting supplemental utilities...searching for boot flash host.............ER
ROR: Could not find internal flash host!
/bin/ash: can't access tty; job control turned off
€€€tset
SYSLINUX 3.31 v1.07 Tue Aug 14 16:43:09 PDT 2012
Copyright (C) 1994-2005 H. Peter Anvin
Debug Serial Port Enabled
Normal
FactoryDefault
OSReinstall
TechSupport
SkipVolCheck
MemoryTest
TestDisks
Loading
18
1B
NETGEAR
ReadyNAS
11/02/2011 ReadyNAS-ProUltra2 V1.8
kernel...........................................................
Loading initrd.gz...........................Ready.
Bringing up RAID arrays...done
Bringing up network...eth0.done
searching for boot flash host.............ERROR: Could not find internal flash h
ost!
SYSLINUX 3.73 2009-01-25 Copyright (C) 1994-2008 H. Peter Anvin
Loading kernel............................................
Loading initrd.gz...........................................ready.
Searching for external boot flash device...Could not find external boot flash!
ERROR: Could not find external flash device!!
