Retired_Member
Dec 11, 2013"TFTP_REQ" On ReadyNas Ultra 2=RNDU 2000
Hi! My RAIDar is showing "TFTP_REQ" How can I enter TFTP mode on ReadyNas Ultra 2 and what files should I use? I also tried usbrecovery with 4 diffrent usb sticks and it did not work :/ Thank yo...
mdgm-ntgr
Dec 16, 2013NETGEAR Employee Retired
The problem is that it has flash paths that are not expected for your model. This suggests either internal wiring was done wrongly in the unit or there is some other problem.
It's definitely a 2-bay Ultra, the Ultra 2?
