Retired_Member
Dec 11, 2013"TFTP_REQ" On ReadyNas Ultra 2=RNDU 2000
Hi! My RAIDar is showing "TFTP_REQ" How can I enter TFTP mode on ReadyNas Ultra 2 and what files should I use? I also tried usbrecovery with 4 diffrent usb sticks and it did not work :/ Thank yo...
Retired_Member
Dec 16, 2013
mdgm wrote: The problem is that it has flash paths that are not expected for your model. This suggests either internal wiring was done wrongly in the unit or there is some other problem.
It's definitely a 2-bay Ultra, the Ultra 2?
Here are some pictures I uploaded:
http://i.imgur.com/XUaQKOf.jpg
http://i.imgur.com/46A0Eti.jpg
http://i.imgur.com/J6QuJL4.jpg
And now when I started it, it started little different fan speed 100% first then slowed down and the serial shows:
Reboot and Select proper Boot device
or Insert Boot Media in selected Boot device and press a key
Normally its only blue light and 100% fan speed
I also found thread with "ERR: Could not find internal fla" probably a diffrent problem than this.
http://www.readynas.com/forum/viewtopic.php?f=64&t=70520
