Retired_Member
Dec 11, 2013"TFTP_REQ" On ReadyNas Ultra 2=RNDU 2000
Hi! My RAIDar is showing "TFTP_REQ" How can I enter TFTP mode on ReadyNas Ultra 2 and what files should I use? I also tried usbrecovery with 4 diffrent usb sticks and it did not work :/ Thank yo...
mdgm-ntgr
Dec 16, 2013NETGEAR Employee Retired
I already put 4.2.25 on your internal flash.
Definitely a different problem to that thread.
When I looked on your system the internal flash had a different path to the expected one and I presume the external ports do as well. So it looks for the flash where it expects it (this is hard coded into the firmware), doesn't find it and returns the error.
