IainClark
Feb 24, 2018Aspirant
The old "Can't see readynas in network" problem again
Hi, i have an ultra 2 running the latest firmware (4.2.31) with one share set up for public access. I can't see it in file explorer. I CAN ping the IP of the box I CANNOT see it when i do \\d...
- Feb 24, 2018
Go into "turn windows features on or off" in the PC, and make sure the SMB 1.0 client is enabled.
Microsoft is deprecating SMB 1.0. It has security issues, but you need it to access your legacy Nas.
IainClark
That fixed it. Thanks for that. I know it's old, but it still works, and it has some nice WD red 3TBs in it, so i don't want to muck with it...
Feb 24, 2018Guru - Experienced User
Glad it helped.
Longer term, you could convert your NAS to run OS-6 (which uses SMB 3.0), or possibly use the Windows NFS client to reach your 4.2.x NAS.
- IainClarkFeb 25, 2018Aspirant
Oh, Is that possible? I didn't think it copuld be upgraded. Is there a guide to upgrading to OS-6? Or is it straightforward??
- StephenBFeb 25, 2018Guru - Experienced User
There are several threads here that explain the procedure (some are very long). Here's one: https://community.netgear.com/t5/Using-your-ReadyNAS/Ultra-6-OS-Upgrade-from-4-2-30-to-OS-6/td-p/1181053
The process is destructive, so you will need a full backup. There is a similar procedure to reverse it - also destructive.
Netgear won't provide support legacy systems that run OS-6, and there is no guarantee that future firmware updates will work on them.
All done, upgraded to 6.9.2.
thank you very much!
