Equinox1
Dec 14, 2015Guide
The Ultimate CPU for Pro 6
What is the most powerful CPU that you can put in the Pro 6? The E7600 and the Q6600 are confirmed, but anybody got any further?
Equinox1
Dec 15, 2015Guide
Learned the hard way: first check the air flow direction ;-)
The air must flow from the front to the back, and the lateral CPU fan must suck the air in.
- eelkDec 16, 2015Aspirant
I was running x3210 on my pro6 for more tthan two years with stock fans without any problems.
The x3230 is the q6700, you can check it on http://ark.intel.com/compare/30797,30790
The most powerful of the same family, Kentsfield, should be the QX6850: http://ark.intel.com/products/codename/23489/Kentsfield#@All
But it has a 130W TDP, so you'll have to seriously think about cooling, I guess.
