alphapapa
Apr 05, 2015Aspirant
the volume data is damaged
Happy Easter to all! I had one hard disk failure on my Readynas Ultra 2 (while on Raid 0). I have formatted both hard disks, sent back the fault one, intalled the lates OS 6.X firmware, rebuilt my...
vandermerwe
Apr 05, 2015Master
Did you test the disk using the long or extended test?
Don't do anything else until you have a backup of the data on the nas.
Your proposed actions should work, however pending sectors are not likely to be "fixed". Is that disk under warranty?
