alphapapa
Apr 05, 2015Aspirant
the volume data is damaged
Happy Easter to all! I had one hard disk failure on my Readynas Ultra 2 (while on Raid 0). I have formatted both hard disks, sent back the fault one, intalled the lates OS 6.X firmware, rebuilt my...
Apr 07, 2015Guru - Experienced User
RAID-1 makes the data more available when a disk fails. That is, in almost all cases your data remains fully accessible when you replace the disk. For many people that is an important aspect.
alphapapa wrote: Anyway, your reply make sense but put me in a worried state...
So why should I bother to set my NAS in Raid 1?
It lowers the odds of data loss, but the odds are still high enough that you do need backups.
If you decide RAID-1 isn't needed, then I'd suggest jbod (two volumes). RAID-0 is fragile - when either disk fails you lose everything in the volume.
alphapapa wrote: ...Maybe I should put it back to Raid 0, enjoy more space (almost 6 TB)...
Lots of people here use external HD for backup. I use another NAS myself. It is wise to have a backup in a format that is easily read on your other device.
alphapapa wrote: ... and pair the NAS with an external 4 TB HD for the back up of "selected content"...
