DoctorNacho's avatar
DoctorNacho
Follower
Dec 04, 2016
Tips: minidlna killing the system performance (fixed)
I use Readynas as my Apple Time Machine backup server.
I have noticed that as or recently the backup has just been going slow like molasses.
Initially I attributed it to Wi-Fi speed, my Mac, etc, but it got me curious to test my hypothesis. I logged in to the readynas via ssh (follow the instructions how to enable it on the netgear site), ran  "top" and noticed that minidlna daemon is at the very top of the list hogging the entire CPU (0 idle CPU). I decided to disable the readydLNA for now and that immediately resulted in almost an order of magnitude better backup throughput, not to mention that the CPU utilization is back to normal range (1.6% user and 3.0%system)
I wonder if anybody else had the same issue and was able to resolve it a different way?
  • This is how it behaves on cool already. And I upgraded the CPU to I think 7600 like 3 years ago. Lots of spiking CPU and overheating on os6 beta 3.
    • StephenB's avatar
      Sorry - have two different problems on the same thread confused me.  I looked at the first post, and saw the RN102, and overlooked your earlier post saying you were running OS6 on your pro.
      • givememynamebak's avatar
        givememynamebak
        Luminary
        Just an update... my overheating issues were solved by ripping the system and power supply apart and cleaning everything, re-apply cpu thermal paste etc.
    • StephenB's avatar
      Pro6 on the latest OS4 version
      That of course has much faster CPU than the RN102.
      You might want to try changing the fan control to balanced or cool, and see if that helps manage the temperature spikes.  That's on the performance tab of the web ui.
  • I'm having the same problem causing overheating.    Thing is taking 99.8% of CPU and causing my nas to overheat.
    I'm using 6.7.0-T180 (Beta 3) on Pro 6.
    3716 root      35  15  151484 106036   6072 R  99.8  1.3 113:59.35 minidlnad
    Dropbox in Cloud doesn't work, had to use the plugin from ReadyNASXtras.
    Discovery page in ReadyCloud doesn't show device once logged in to manage my NAS (have to search by serial number for some reason)
    • mdgm-ntgr's avatar
      mdgm-ntgr
      NETGEAR Employee Retired
      Any clues in e.g. upnp-av.log or systemd-journal.log as to why it's using so much CPU?
        givememynamebak
        Luminary
        I'll have to inspect the logs when I get a moment.  I shut off UPNP for now but I suspect it has to do with large libraries.
        I also have CPU spikes of 75-85C when using Sabnzb and it's repairing & extracting.  Never had this with OS4... sigh.
  • StephenB's avatar
    Did you look in the DLNA logs?
    You could try re-enabling the service, but disabling it for all the shares.  Then enable one share at a time, and see when the problem recurs.
ProSupport for Business
