rcampbellin
Aug 22, 2012Aspirant
TM Backs up too much
I've got an issue that's similar to some: Time Machine is backing up way too much. As I write this, it is backing up over 15 GB of data; there should be nearly nothing that has changed since the las...
mdgm-ntgr
Aug 22, 2012NETGEAR Employee Retired
Well if it's not the VMs it might be from another app you use. Not knowing what apps you use it'd be difficult to guess.
