kncowans's avatar
kncowans
Virtuoso
Mar 12, 2016
Total Capacity available on ReadyNas 214 with 4 x WD Red 5TB HDD
Hello all   Can someone please confirm something for me?   I have a ReadyNas 214 that currently has a single WD Red 5TB HDD in it which gives me a total of 4.54TB available.   Am I correct in b...
  • StephenB's avatar
    Mar 12, 2016
    The NAS reports TiB (1024*1024*1024*1024 bytes per TiB), drive manufacturers use TB (1000*1000*1000*1000 bytes per TB).
    5 TB is the same as 4.55 TiB.  (The NAS is taking about 4 GB for the OS  and swap, but that is in the third decimal place when you scale up to TB.)
    With 4x5 TB you'd have a 15 TB volume.  That is the same as 13.6 TiB - the formula is 15*(1000/1024)*(1000/1024)*(1000/1024)*(1000/1024)
ProSupport for Business
