birdnugg
Aug 19, 2018Aspirant
Transfer data to ReadyNAS 214 using spare bay
I have an old 2TB Seagate GoFlex Home that died and am upgrading to the ReadyNAS 214. (The drive itself seems good, but the base is toast.) The ReadyNAS has 3-3TB drives with the fourth bay open. ...
Retired_Member
Aug 19, 2018Hi birdnugg, as you are on xraid the 214 would try to integrate the newly inserted disk into the existing array, which is not what you need.
So, to my judgement to need to play the sata-usb game, unfortunately.
Other community members might have further suggestions. Good luck with fixing and kind regards.
bedlam1
Aug 19, 2018Prodigy
Another solution may be to install the 2TB drive into a spare Sata Port in your PC and transfer the data across your network using Windows/Mac.
If you have a 1GB network this would be quicker, you also need to have a backup regime in place for your NAS to another device (USB Drive/Cloud etc.)
Edit: The Goflex is either NTFS or Mac OS as far as I can tell
