sgpearman
May 23, 2012Aspirant
Transmission Access from Internet
Hi Guys, I've been trying to setup access to the transmission interface so I keep an eye on downloads whilst I'm out and about :roll:. But I'm having a few difficulties and wondered if anyone ca...
JarnoG
May 25, 2012Guide
You can try looking in the log of your router. Most likely it has entries for the port-forwards it does.
In the past I also had some problems with an old router of mine that did weird things with the DMZ'ed pc when I also set other port-forwarding rules. You might want to try to disable DMZ and forward the applicable ports manually (8081 for the webgui and 443 for Frontview, port 51413 for the peer connections is done using upnp if upnp is turned on on your router).
Lastly, if you want transmission to accept connections from all IP's, you could also use
Maybe just turning the whitelist off also does the trick, but I'm never looked into that.
"rpc-whitelist": "*",
