cserba's avatar
cserba
Transmission Error:Permission denied
Hi, I've got a problem with a Transmission (3.00.6 from poussin dropbox version) in my ReadyNAS 104 (6.1.8). After OS re-install and destroying my 2TB HDD (called in my twoTB_Seagate) I recreated it. Installed my application included Transmission above mentioned. I was trying to download Catzilla torrent-file from here: http://www.catzilla.com/download with Transmission: and I am getting error from transmission - Error: Permission denied. I was able to edit settings.json file with an online editor for it: http://www.jsoneditoronline.org/ and edit the place and directory of download and incomplete files. Right now I can't even copy files or setting.json file to my HDD from the NAS 104.
My second question is that I installed an application called: PHPsysinfo for ReadyNAS. I was able to read some information and my ext4:rootfs(rw, noatime, nodiratime, user_xattr, barrier=1, data=ordered) and ext4:/dev/md0(rw, noatime, nodiratime, user_xattr, barrier=1, data=ordered) is used up to 96%, how can i delete some files from it? Or free up space. Maybe from the first use the transmission tried to download files to that location.
I am noob from ssh, so maybe some kind of step by step help could be for me very helpful.
Thank you very much. :)
  • I have set the download location and incomplete location: /twoTB_Seagate/Transmission/Downloads. And my volume name is called twoTB_Seagate (because it is my biggest in the NAS 2TB Seagate) but right now for some reason I can't download to my PC the settings.json file. I was able to do it 2-3 days ago. But i remember my settings.
  • super-poussin wrote:
    will contact you soon - asap
    thank you kindly
  • hi,
    I have the same problèm. i have change destination folder in setting files but when i want donwload files Tranmission don't have permission to write in the DL folder. can you help me?
  • Yep. Me too and the dreaded ' Error: Not a directory'.
    I can't download my .json either. Poussin, please help!!!
    Transmission was awesome when I was running Raidiator 4.x, Now I've upgraded to OS6 I can't get it working.
ProSupport for Business
